Error 0xABA88D4B When Clicking Empty Event Cases Causing LabVIEW to Crash
Updated Sep 28, 2024
My LabVIEW crashes after selecting "Remove Empty Cases" of an event case on the Block Diagram.
I received the following error:
DAbort 0xABA88D4B in undo.cpp
Error 0xABA88D8
This issue is caused by a corrupt event case. To resolve this error, try the following troubleshooting steps:
  • Delete the event case and recreate a new one.
  • Add another case to the event, insert a random function(constant/control/indicator), then remove empty cases
