Issues With Re-Arm Behaviour of Alarm in VeriStand
Updated Mar 26, 2024
  • VeriStand
Re-arming alarm with procedure in VeriStand does not allow re-use once the alarm source value returns to the acceptable range while the alarm status remains tripped. How do I reset the alarm?
The alarm resets if it is disabled and then enabled back in the Rules section of the Alarm Monitor tab.
You can incorporate a LabVIEW application that does this operation automatically. The code snippet provided below can serve as a foundation for your implementation:
