It's important to note that the slots for the controller are custom-made and, as such, extending them with a specific cable from the chassis is not recommended. These slots are designed for short-distance communication within a single device.
Consider using an Ethernet chassis, such as a cDAQ-9181, which has a single slot and can be easily connected to an Ethernet network. This will allow you to access it from your local computer, even over long distances, without having to worry about cable connections. In essence, an Ethernet chassis is designed to offer a dependable and effective solution for your communication requirements.
