Error -201475 During PXIe-4112 Self-Test in NI MAX
Updated Feb 9, 2026
  • PXIe-4112
I installed a new PXIe‑4112 module into the PXI chassis; however, running the self‑test in NI MAX returns Status Error: ‑201475. Below is the error information.
From document Installing the Auxiliary 48 V Power Source on the PXIe-4112 - NI, we can know it needs install the auxiliary 48V power source on the module PXIe-4112 first. Then power on chassis and start to use it normally.
Please also verify that the auxiliary 48 V power source is operating normally. If the issue persists, try replacing the auxiliary power supply.
