Error -201377 When Using NI-DAQmx With a Real-Time Controller in LabVIEW
Updated Apr 26, 2024
  • CompactDAQ Controller
  • CompactRIO Controller
  • PXI Controller
I have a data acquisition system, based on an NI Linux Real-Time (RT) controller and different DAQ modules that are being accessed and controlled through the NI-DAQmx driver. Even though I am setting the corresponding NI-DAQmx tasks correctly, I keep getting error -201377, when trying to start the task.
Error -201377 occurred at an unidentified location
Possible reason(s):
Device is unusable while firmware update is in progress.
The error is shown in the following dialog box:
Error -201377
I have reviewed in NI MAX the current status of my RT controller, and I am not currently upgrading the firmware. What could be causing the issue?
Error -201377 could be caused by not having the latest available firmware version installed on your RT controller. To solve the issue, upgrade the firmware on your controller:
