I am trying to establish UDP communication by using UDP Multicast Open VI with UDP Write VI to send UDP signal, and UDP Open VI with UDP Read VI to receive the signal, in LabVIEW as shown as follow:
When I run the code, I get the following error:
Error 109 occurred at UDP Write in UDP vi
Possible reason(s):
LabVIEW: (Hex 0x6D) Multicast connections cannot send to singlecast addresses.
