We could always try to refer to the DAQmx Python
documentation for APIs usages details.
For the trigger signal source, I think you could follow the steps mentioned in KB: Use SMB Connector on PXI(e) Controller to Route Trigger Signals , to invoke the "cfg_dig_edge_start_trig", and set the source as [nameofthe controller/TRIG_SMB] like what the LV example did in the KB.
Please refer to a simple Python example code below to achieve this:
import pprint
import nidaqmx
pp = pprint.PrettyPrinter(indent=4)
with nidaqmx.Task() as task:
clk_rate = 2.0e6 # Sampling freq. It is determined by the ext. clk rate. Unit: [Hz] Please note that the maximum sampling freq. of DAQ board(PXIe-6378) is 3.5 MSa/s/ch.
tr = [-0.1,1.0] # Timerange to plot.
num_pts = int(clk_rate * (tr[1]-tr[0])) # Total data acquisition time.
task.ai_channels.add_ai_voltage_chan("PXIe6378/ai0")
task.timing.cfg_samp_clk_timing(rate=float(clk_rate), samps_per_chan=num_pts) # Configure the clock configuration.
task.triggers.start_trigger.cfg_anlg_edge_start_trig(trigger_source = 'APFI1', trigger_level=1.5) # Setup the trigger conditions
print("1 Channel N Sample Read: ")
data = task.read(number_of_samples_per_channel=num_pts, timeout=100)
pp.pprint(data)
Note: we're simulating a PXIe-6378 device in NI MAX to run the Python script, please change the arguments of add_ai_voltage_chan for your case.
