Can I Connect a Database Using LabWindows Base Edition?
Updated Feb 14, 2024
  • LabWindows/CVI Base
  • LabWindows/CVI SQL Toolkit
I am currently using LabWindows Base edition and would like to automate my data report in the form of database format such as Access database or SQL database. Is is possible to do database connection with LabWindows Base version?
The database connectivity functions are only available in LabWindows Full edition and not in Base edition. However, you can install LabWindows/CVI SQL Toolkit and use it in LabWindows for database function purposes.
