If there are more than two transitions in the state machine, the sequence becomes false when the order of the transitions is changed manually.
Here are the steps to reproduce:
- Open the State Diagram Editor from the block diagram of LabVIEW
- Right-click on the Choice state and click Record Transitions.
- Change the transition order randomly and click apply.
- After changing the order, while running the program based on the chosen option the program is not showing the correct state.
