Deploy and Run Real-Time Startup Executable on SD Card in cRIO
Updated Feb 8, 2024
My cRIO is connected to an SD card. Can I deploy my real-time startup executable to the SD card?
Yes, you can deploy your real-time startup executable to the SD card. You can change the target destination directory to your SD card when you configure the executable build specification as shown below:
location
Generally, the U drive will refer to the SD card. If you cannot find your SD card, refer Why Can't I See my SD Card or Directory on my cRIO Controller?
