LabVIEW Statechart Module Not Listed in VIPM
Updated Feb 8, 2024
  • LabVIEW Statechart Module
I would like to install LabVIEW Statechart Module in VIPM (VI Package Manager), but the module is not listed in VIPM.
You need to install the LabVIEW Statechart Module via VIPM version between 2019 until 2022.
To install older version of VIPM (for example VIPM 2020) follow the following steps.
  1. Uninstall the currently installed VIPM using Windows add or remove program.
  2. Remove VIPM installation from NIPM (NI Package Manager).
  3. Install the older version of VIPM using offline installer.
