If the same issue still persists, try to monitor your PXI chassis temperature either via NI MAX or
programmatically with LabVIEW . For the VI example you can have it from the related link below. This monitoring will identify whether it's shutdown during the chassis exceeds the temperature limit or not. If yes it was expected issue, else kindly please reach
NI Technical Support .
