When attempting to run the ranged self-calibration on the PXIe-5842 with 54 GHz Frequency Extension and the frequency range is set to anything other than the full range (i.e. min frequency ≠ 0 and max frequency ≠ ∞) in InstrumentStudio, I get the following out of range error:
I will get the same error in LabVIEW when using either the NI-RFSG or NI-RFSA
Self Calibrate Range VI and the frequency range is set to anything other than the full range:
