Does USRP-2974 Configuration Persist After a Reboot
Updated Feb 8, 2024
  • USRP-2974
I have a USRP-2974 with build in Real Time OS (Operating System). Does the ifconfig up or down will disappear after reboot the machine and am I need to turn SFP+ off every time when use the USRP-2974?
For your information, it should remain disabled even after the USRP-2974 reboot. Unless the USRP-2974 been reset then you may need to reconfigure from start.
