Error -1074097802 When Using NI Digital Pattern Instrument
Updated Oct 20, 2026
  • PXIe-6570
  • PXIe-6571
  • NI-Digital Pattern Driver
When executing the NI-Digital Pattern VI in LabVIEW, the following error is displayed:
Error -1074097802 occurred at niDigital xxx.vi
Possible reason(s):
An unexpected hardware failure has been detected. Please contact NI Technical Support or visit ni.com/support for further assistance.
The error message appears in the dialog box shown below.
To troubleshoot and resolve this issue, please perform the following steps:
  1. Update the NI-Digital Pattern Driver
    • Install the latest version of the NI-Digital Pattern Driver and confirm that it is compatible with the version of LabVIEW being used.
  2. Run Basic and Intermediate Self-Tests
    • Execute both the Basic and Intermediate self-tests on the module to identify any hardware-related issues.
    • If the self-tests complete successfully without reporting any errors, check whether the LabVIEW application can run correctly.
  3. Reset the NI MAX Configuration Database
  4. Verify that the NI Digital Pattern device is correctly recognized and identified in the system
    • Refer to the relevant troubleshooting guide and perform the recommended validation steps. For example, verify whether error -88705 appears in NI MAX when the PXIe-6570 is removed, and check whether the device name or configuration will be changed once modified and saved.
If the issue remains unresolved after performing the troubleshooting steps above, please contact NI Support and provide the following information to facilitate further investigation:
  • An NI MAX Technical Support Report.
  • Confirmation of whether an MXIe remote controller (such as the PCIe/PXIe-836x, 838x, or 839x series) is being used, along with the model numbers of the chassis and any other modules installed in the system.
  • Information on whether the card has functioned properly in the past and, if so, when it was last known to be operating normally.
  • Details of any recent changes to the software, hardware, operating system, or system cabling/connections.
  • Screenshots of the LabVIEW block diagram for code review and to identify any potential software-related issues, such as repeatedly opening and closing device sessions or hardware references during execution.
