ISRM-PSI5 (C14)
ISCM-PSI5 AMS (C14)
Currently, NI does not provide C Series modules that support PSI5 communication. However, NI Solution and Integration Partners offer and support the following PSI5 compatible C Series modules:
Alternatively, you can use an FPGA configurable module such as the NI-9401 with some additional circuitry to implement PSI5 communication protocol on your own.
You may refer to the Developing Digital Communication Interfaces with LabVIEW FPGA article for developing your own PSI5 communication protocol code or any custom digital communication protocols.
