I am facing an issue when using NI 4303 card with VeriStand 2021. The requirement is using Hardware Time Single Point Acquisition (HWTSP) mode, and according to the article
DAQ Devices with Hardware-Timed Single Point Sampling Mode Support, NI 43xx cards are supported while Waveform Mode of acquisition is working fine.
Is there any workaround for us to use NI 4303 cards in HWTSP mode without error 50258 occurs as below?
