This error occurs because the 32-bit Module Path of your Instrument Driver Software Module is empty. Since NI Measurement & Automation Explorer is a 32-bit process it needs the 32-bit DLL to properly load the configuration from the IVI Driver.
To solve this issue follow the steps below.
- Open NI Measurement & Automation Explorer and navigate to My System>>IVI Drivers>>Advance>>Intrument Driver Software Modules.
- Click over the instrument driver that is having the issue and go to the general tab.
- Click on the Browse... button from the Module Path (32-bit) and select the appropriate 32-bit dll. See the image below.
Note
The 32-bit DLLs are usually located at C:\Program Files (x86)\IVI Foundation\IVI\Bin.
