Result Processing Dialog Does Not Appear in Custom Environment of TestStand.
Updated Aug 27, 2021
  • TestStand
I tried to migrate my project from TestStand 2019 to 2020. I used TestStand 2020 Migration Utility and opened my project without any issue. However, I can't open the Result Processing dialog window when I load my own Environment Configuration - I can click on the menu item, but nothing happens.
Step1: You should update the type of Model and set the right one.
At the top, select Configure:
Then Station Option:
In the pop-up menu go to the Model section and select the exact Station Model:
step2: open NI_DatabaseLogger and NI_ReportGenerator located in
C:\Program Files (x86)\National Instruments\TestStand 2020\Components\Models\ModelPlugins
and update types from those sequences (update type from loaded sequence option)
- so type in the main test seq will be updated to the newest version.
 Side effect: no result processing configured - everything must be configured, from the base.
