Il contenuto non è disponibile nella lingua selezionata.
Verrà mostrato il contenuto in un'altra delle lingue disponibili. Il tuo browser potrebbe avere delle funzionalità di traduzione.
ActiveX Error While Running LabVIEW VI From TestStand
Updated Oct 18, 2024
  • TestStand
  • LabVIEW Runtime
I’m running a LabVIEW VI from TestStand UI. When LabVIEW Full Development Environment License and TestStand Base Deployment Engine License is active everything works fine. But I need to run an application without LabVIEW Full Development Environment. When LabVIEW License is not active I got an ActiveX Error:
Error calling sequence Test UUTs.
Error loading step 'Scope_Reset' of sequence 'MainSequence' in file 'TS_v20.0__KompassiKnobTester_v08.seq'.
Unable to launch the 'LabVIEW.Application' ActiveX Automation server.
CoCreateinstance returned '0x80080005':
Server execution failed.
Please go to Adapter Configuration to [Start > Programs > National Instruments > TestStand x.x > Sequence Editor > Configure > Adapters > LabVIEW > Configure] change the default setting to use the LabVIEW Runtime Engine.
Save everything, please be sure that there is no error on TestStand, and try to run it from UI.
