LabVIEW 2023Q3 Crashed When Building Executable in Different Language Windows 11 Version
Updated Jan 24, 2024
  • LabVIEW 2023 Q3
  • While building executable file, LabVIEW crashed and displayed the following error:LabVIEW 2023Q3 crash.png
  • LabVIEW building progress hang when creating executable file.
The crash (and likely the hang) when building an EXE or a PPL on a Japanese / Korean Windows OS is caused by having a Windows username with non-English characters.
There is a cache that EXE and PPL builds use that is normally created in the LabVIEW Data directory which by default is in the user's Documents folder, and there is an issue with opening the cache if its path on disk has non-English characters.
Recommended workaround for this issue is to add the following to the LabVIEW INI file:
AppBuilderCacheRoot="<path>"
Here <path> can be any directory whose full path only has English characters, but I suggest setting the token as follows:
AppBuilderCacheRoot="C:\ProgramData\National Instruments\AppBuilderCache"
