Access Violation Error in LabVIEW When Using Channel.vi
Updated Oct 4, 2024
I am facing an access violation error when trying to add a constant to the Resource Name of the NI DCpower Initialise with Channels VI.
The error message is as follows:
We apologize for the inconvenience
LabVIEW 2019 encountered a problem and needs to close. You can help us diagnose and fix this problem by sending this report directly to National Instruments.
Exception: Access violation (0xC0000005) at EIP=0x00007FFA85B501AC
Version: 19.0.1f5 (64-bit)
How can I fix this?
This particular error message appears due to a bitness incompatibility. According to the error message, it pops up in a 64-bit LabVIEW.
To resolve this issue, you need to install and use a 32-bit LabVIEW.
The 64-bit NI Software doesn't have any speed improvements against the 32-bit NI Software. The 64-bit NI Software is used for special projects that require advanced memory capacity.
In case you don't have a special project like this, NI recommends using 32-bit NI Software as this has a wider range of compatibility with drivers.
