Resize Objects Proportionally in LabVIEW
Updated Dec 29, 2023
  • I am trying to resize my indicator in LabVIEW but it ended up losing its original proportions. Is it possible to proportionally change the size of a control or indicator in both directions?
LabVIEW controls and indicators can be resized proportionally by holding the Shift key while drag-resizing. This results in the following behavior:
Note: this feature is not exclusive to LED indicators. You can Shift-drag-resize any object that can resize in multiple directions, including objects on the block diagram.
