Unable to Find Firmware File to Perform Firmware Update on RIO Target
Updated Oct 8, 2025
  • NI-9145
  • NI-9144
  • CompactRIO Controller
  • NI CompactRIO
I tried following the article Upgrading or Downgrading Firmware on an NI Linux Real-Time Device, but was unable to find the folder path <Program Files>\National Instruments\Shared\Firmware\
How can I make sure my firmware files are installed?
1. Go to NI Package Manager >> Installed and look for NI CompactRIO and click on the Install or remove related packages button.
2. Confirm that NI-RIO cRIO Firmware for NI Linux-RT Real-Time Embedded Targets is checked. If not, check if and install it.
Firmware updates for NI devices are distributed with the device drivers. If there is a firmware update needed and the appropriate file is not found in the directory, updating the driver should provide the needed firmware file.
