cRIO Install NI Linux RT System Image 2019
Updated Sep 29, 2023
  • CompactRIO Controller
  • NI Linux RT System Image
I installed NI Linux RT System Image 2019 but when tried perform cRIO installation in NI MAX, there is no 2019 version option in the available Base Images list.
The NI Linux RT System Image supports cRIO installation only from 2020 onwards.
For older version, you will need to use the legacy installation method.
NI Linux RT System Images 2019 only support for PXI controller.
