There is no 64-bit version of the LabWindows/CVI Signal Processing Toolkit. This toolkit was removed in CVI 2017 and no 64-bit version of it was created.
The options to continue using the JTFA functions are:
- Do not update the application to 64-bit (keep it as 32-bit).
- Find another library that provides these capabilities.
- Build the functions into a 32-bit executable and use an inter-process communication mechanism to communicate between the 64-bit application and the 32-bit application. This will have performance implications, which depending on how the functions are used could make this option not viable.
