What is the Power Dip Duration NI Chassis can Withstand?
Updated Sep 21, 2023
  • PXI Chassis
Can my PXI chassis withstand a power dip of 200ms?
NI chassis compliance to IEC 61000-4-11. Assuming the frequency of power supply used is 50Hz, this means that NI chassis can withstand approximately 1/50Hz = 0.02s of power dip. If the power dip is longer than 0.02s, the chassis will shut down.
