Check if RFSA is installed, if not, proceed to install it
After confirming RFSA is installed, please proceed to:
- Restart your PXIe system to ensure that your system is not running NI RF-related programs.
- Make sure that your VST RF IN and RF OUT are not connected to any external.
- Allow the module to warm up for 30 minutes after the PXI Express chassis has powered on and the operating system has completely loaded before you use the module or perform self-calibration.
- Open the NI-RFSA soft panel, click Device/System >> Calibration >> Self Calibration.
- Observe whether the self-calibration can be run successfully without error.
- In case to present any error, please take screenshots of the error and proceed with the next procedure.
If the self-calibration fails, please proceed to the following steps:
- Open Start >> All Programs >> National Instruments >> Vector Signal Transceivers >> VST Self Calibrate
- After opening the software, make sure your VST is selected, then click Perform Self Calibration.
- In case to present any errors, please take screenshots of the errors, and contact NI Technical Support for further assistance.
