Why Is LabVIEW Prompting Warnings When I Try To Save VI With RFmx Driver For Previous Version?
Updated Aug 25, 2023
  • RFmx
  • RFIC Test Software
When I want to save VIs with RFmx driver API for previous version, LabVIEW prompt the warning as below:
How can I save VIs containing the RFmx driver for previous version?
This is an expected result. Those VIs which could not be copied are from RFSG or RFSG Playback related LLB files. It is not related to the RFmx driver.
The VIs are marked as toolkit vi , the user could not copy it to another locations.
Even with the warning message appeared , VI saved for previous version will work fine without any broken arrow.
