How To Get The Maximum Payload Size For Bluetooth Generator
Updated Aug 23, 2023
  • RFmx Waveform Creator
  • Test Toolkit for Bluetooth
Bluetooth can support multiple packet types , so you can generate different bluetooth signal.  Different packet types define the different payload ;  The payload size impact the time length of the whole frame . Before you set the payload , you should know the maximum size of payload . How could you get the maximum size of different packet type RFmx Blutooth support ?
1.Select the packet type you wanted;
2.Click the button "Configure Payload"
3.Select the Payload Length Mode as Maximum Length ;
Like below picture showing steps:
You can change the packet type value , then follow above steps getting the maximum payload size;
