RFmx WLAN support noise compensation feature to improve EVM performance. You can see below setting parameters in RFmx WLAN setting panel:
From above setting panel , you can add the frequency point and channel bandwidth manually ; You can also click Load 2.4G Channels and Load 5G Channels buttons to add calibration table; You also find it is support to import a file setting the frequency points table, like below picture:
When you click the button to import a file , but you could not find the example file , How could you create a example file for multiple frequency points ?
1.You can see what format the RFmx WLAN needed
You should create one txt or csv type file , which is a comma delimited format; 2.Try to create one txt file , then write some frequency points and bandwidth into it , like below picture:
3.Load the file success;
Then click the button "Multiple-Point calibrate" , you can see the noise calibration working well;
After some mins , you can see the calibration pass;
