I am using FlexLogger 2023 Q1 version with PXIe-6251 to acquire voltage in analog input single-ended mode. However, an error as follow occurred:
Given the specified Reference Clock Source, you must set the Reference Clock Rate to a value equal to the frequency of the supplied signal. Properties: RefClk.Src, RefClk.Rate
How to fix the error?
