I am using the shipping example
C:\Users\Public\Documents\National Instruments\TestStand 2020 (64-bit)\Examples\TestStand API\Building a Sequence Using API\LabVIEW to build a TestStand sequence file using XML file.
I realized that I am unable to get the expression value defined in the XML file to be written into the newly generated TestStand sequence file.
XML Snapshot:
Generated sequence file:
We can see that the
Pre-Expression here is empty although we have defined it in the XML file.
