Is it correct that the PCI-4462 card can be used on a motherboard with any PCI version between PCI 2.0 - PCI 3.0?
Updated Oct 4, 2024
  • PCI-4462
Is it correct that the PCI-4462 card can be used with a motherboard supporting any PCI version between PCI 2.0 - PCI 3.0?
Since the PCI-4461/4462 have a 64-bit PCI-connector, a corresponding slot with PCI-version >= 2.1 must be available. If it's a 32-bit card, a 2.0 slot would also be supported. Whether a slot is a 32-Bit or 64-Bit slot can be identified by the shape of the PCI-connector (see related links section).
