Why Does the NI-RFSG Soft Front Panel Not Show Up on Instrumentstudio When Using My VST?
Updated Aug 9, 2023
  • PXIe-5644
  • PXIe-5645
  • PXIe-5646
The NI-RFSG Soft Front Panel on InstrumentStudio is not showing up when using my VST. The Classis NI-RFSG Soft Front Panel works fine.
The InstrumentStudio NI-RFSG Soft Front Panel is not supported on VST models:
  • PXIe-5644
  • PXIe-5645
  • PXIe-5646
To use NI-RFSG with these VST models you need to use the NI-RFSG LabVIEW API or the Classic NI-RFSG Soft Front Panels.
