Using NI LabVIEW CLI Without a GUI on a Linux Server
Updated May 1, 2025
  • NI LabVIEW Command Line Interface
  • Linux
The LabVIEW Command Line Interface (CLI) provides a powerful way to interact with LabVIEW applications and perform various tasks. In this article, we will explore how to utilize the LabVIEW Command Line Interface (CLI) without the need for a Graphical User Interface (GUI) which the Linux Server does not offer.
Xvfb is a display server implementing the X11 display server protocol, it will help us run applications that require a Graphical User Interface (GUI).
Installing Xvfb:
  1. Open a terminal on your Linux server and run the following command to install Xvfb
    • sudo apt update
      sudo apt install xvfb
  2. Confirm installation
    • xvfb-run --help
Graphical User Interface (GUI) is now present in your Linux server, and you can use LabVIEW Command Line Interface (CLI) without any issues.
