Steps to Update Firmware on the FSL-0010 to Enable Fast Switching
1) On the system connected to your FSL-0010 - Download, Install, and Run the "Set Fast Switch.exe" attached (see the bottom of page) to this article.
2) Exe will prompt you to select a QuickSyn Module to enable fast switching on (must be FSL-0010)
3) Once the FSL-0010 is selected, the exe will attempt to add the fast switching option and you will be updated on your devices fast switching setting. Either of the following messages will be provided.
Please note, this should only be used with the FSL-0010! The executable will fail with a "This tool can only be used for FSL-0010 Modules" error if the model name doesn't contain the string "0010". It could work on FSW-0010 models, but won't work for 0020 models.
