Modular Data Acquisition
High-Performance Test
At the new language copy file, right click the configuration settings file that you would like to edit, eg. UIControlString.ini.
Select Properties, go to Security tab.
Click Edit to change the permission.
On the Group or user names, click on Users (<Device Name>\Users). Check on Full Control, Modify, and Write box.
Click OK to save the changes and close all the window pop out.
Now, you may edit the configuration settings file.
Localizing TestStand to Different Languages
TestStand LabVIEW UI Crashes When Using Chinese Characters
