Error -1074118640 While Generating on Both TX Ports of My USRP-2901
Updated May 6, 2022
  • USRP-2901
I try to generate 2 different sinewaves on both TX ports of my USRP but I get error  -1074118640 during the execution.
This error is caused because you are trying to generate two signals with different carrier frequencies. The USRP-2901 TX ports share the same Local Oscillator so you need to use the same configuration.
