I've experienced some issues with my cRIO-90xx. The device reboots approximately every 60 seconds and checking on PuTTY it is possible to see:
JBD2: Failed to read block at offset 28392
EXT4-fs (sda4): error loading journal
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(8, 4)What does mean and how can I fix the issue?
