Accessing VeriStand Model Generation Support Documentation
Updated Jun 1, 2022
  • VeriStand
  • MATLAB
The VeriStand Model Generation Support add-on allows the creation of models within the MathWorks Simulink® environment that are compatible with VeriStand.
This article describes how to access the  VeriStand Model Generation Support add-on documentation.
Software required:
  • MATLAB® R2020 and later releases.
Prerequisites:
You can access the VeriStand Model Generation Support documentation at any time following the next steps:
  1. In MATLAB®, open the Add-Ons dropdown menu located in the ribbon bar and select Manage Add-Ons.
  1. In the Add-On Manager, scroll down or use the search field to find the VeriStand Model Generation Support addon, then click on the corresponding ellipsis and select Open Documentation.
  1. The VeriStand Model Generation Support documentation will appear as a standalone window. You can use the Search Documentation bar, the contents tree pane, or the links embedded in the pages to navigate through the documentation.
Next Steps
