Emulation Manager Error in Simulation Mode on PXIe-5646
Updated Oct 18, 2023
  • PXIe-5646
  • PXIe-5644
  • LabVIEW 2015
  • LabVIEW 2015 SP1
I'm using Vector Signal Transceiver (VST) PXIe-5646, LabVIEW 2014 SP1 and LabVIEW Instrument Design Libraries for Vector Signal Transceivers 14.0 version. There are constant crashes when I try to run code in the FPGA simulation mode. And I get a LabVIEW FPGA error (see below). There are no errors while running the code on the FPGA target.
LabVIEW FPGA reported the following error:
An internal software error in the LabVIEW FPGA Module has occurred. Please contact National Instruments technical support at ni.com/support.
An internal error has occurred in the emulation manager.
To fix this issue, you need to update LabVIEW and drivers to the software versions supported by the PXIe-5646. The list below is the version of LabVIEW and drivers that will work
