PXIe-8240 Not Recognized Correctly in Device Manager
Updated May 7, 2026
  • PXIe-8240
I have a PXIe-8240 and have but the card does not appear to be recognized correctly in device manager.
It shows under Other devices as an Ethernet Controller, but with a yellow warning triangle.
When I open the device properties, it says:
The Drivers for this device are not installed. (Code 28)
The PXIe-8240 requires 2 pieces of software to be correctly identified:
  1. NI PXI Platform Services
  2. PXIe-8240 Firmware and Additional Drivers Download
Both drivers are required to correctly identify and use the PXIe-8240.
