Error -1073807343 Occurs for FSL/FSW-0010, 0020
Updated Apr 28, 2022
  • Phase Matrix RF Signal Generator Device
I use FSL/FSW-0010, 0020. It worked fine but today it causes error  -1073807343 when I start to use. Why?
When you change USB port connecting to the device, it is recognized as different COM. You need to bring back to the original USB port. Then, the error will be disappear.
