The sbRIO-9605 does not support the mentioned IP addressing mode. It only supports the
Static and
DHCP or link local modes. However it is possible to set up a startup VI which will automatically reboot the sbRIO-9605 until it gets the IP address from the DHCP server. Typically, when set to
DHCP or link local mode, the sbRIO-9605 automatically attempts to connect to the network using DHCP. If DHCP server is not available, the controller connects to the network with a link-local IP address with the form
169.254.x.x. Writing a LabVIEW code which will use a case structure to determine if the current IP address belongs to
169.254.x.x and rebooting every time it does get an IP from that range will eventually set the device stay booted only if it gets an IP from the DHCP server.
