Output Calibrated Contour Points From Vision Assistant
Updated Apr 28, 2023
  • Vision Assistant
You can use Vision Assistant in LabVIEW to prototype and test image processing algorithms or applications. After the test, you may output parameters related to the algorithms to display the results or further analysis them. In this article, we will show how to output the calibrated contour points from Vision Assistant.
You can use IMAQ Get Contour Info VI to extract calibrated contour points.
Connect Image Out from Vision Assistant to Contour Image input from IMAQ Get Contour Info VI as shown in the image below. The output Points (real) refer to calibrated points.
contour points(real)
