Can I Activate LabVIEW Community Edition Offline?
Updated Apr 22, 2022
I am trying to activate LabVIEW Community Edition on a computer that does not have any network connection. Is this possible?
No, currently offline activation is not available for LabVIEW Community Edition. You can install offline using the ISO installer file downloaded on a computer that is connected to the internet; however, for activation, you will have to login to the NI Account used to download the ISO installer file, which requires network connection. After activation is done via network, you can disconnect from the network and use LabVIEW offline.
