If creating a new Custom Device:
- Install a release of the VeriStand Custom Device Wizard for LabVIEW 2021
- Generate the Custom Device project template in LabVIEW 2021 64-Bit
If migrating an existing Custom Device:
- Download or otherwise acquire the source of your custom device
- Make a backup of the source files if requiredSave and close the project
- Save and close the project
- Open the .lvproj in a text editor, such as Notepad++
- On the generated RT CompactRIO Target - Linux x64 target, replace the attributes with the correct attributes for a LinuxRT PXI chassis. To do so, replace the following lines in the XML:
<Item Name="RT CompactRIO Target - Linux x64" Type="RT CompactRIO">
<Property Name="alias.name" Type="Str">RT CompactRIO Target - Linux x64</Property>
<Property Name="alias.value" Type="Str">0.0.0.0</Property>
<Property Name="CCSymbols" Type="Str">TARGET_TYPE,RT;OS,Linux;CPU,x64;DeviceCode,7735;</Property>
<Property Name="crio.ControllerPID" Type="Str">7735</Property>
<Property Name="host.ResponsivenessCheckEnabled" Type="Bool">true</Property>
<Property Name="host.ResponsivenessCheckPingDelay" Type="UInt">5000</Property>
<Property Name="host.ResponsivenessCheckPingTimeout" Type="UInt">1000</Property>
<Property Name="host.TargetCPUID" Type="UInt">9</Property>
<Property Name="host.TargetOSID" Type="UInt">19</Property>
<Property Name="host.TargetUIEnabled" Type="Bool">false</Property>
<Property Name="target.cleanupVisa" Type="Bool">false</Property>
with the following lines:
<Item Name="RT PXI Target - Linux x64" Type="RT PXI Chassis">
<Property Name="alias.name" Type="Str">RT PXI Target</Property>
<Property Name="CCSymbols" Type="Str">TARGET_TYPE,RT;OS,Linux;CPU,x64;</Property>
- Save the .lvproj file in your text editor.
- Re-open the LabVIEW project. The CompactRIO Linux64 target will now be a supported PXI Linux64 target and will contain the correct build specifications for a Linux64 target.
- Remove any unsupported or undesired targets from the LabVIEW project and the Custom Device XML.
- This is done by deleting the <Source> sections that have a SupportedTarget attribute of Pharlap, VxWorks or Linux_32_ARM from the <CustomDevice>\<CustomDeviceVI>\SourceDistribution section within the XML.
- Under the new Linux64 target, expand "Build Specifications" -> "Engine Release" and ensure that the "Source Files" section has "RT Driver VI.vi" as Always Included.
- Develop your Custom Device code as usual.
- Build the Engine build specification under the Linux PXI target, and this will successfully run on both a LinuxRT PXI and a LinuxRT 64-bit CompactRIO target.
