Access Timestamp of XCP Packet using ECU Measurement and Calibration Toolkit
Updated Jul 29, 2022
  • ECU Measurement and Calibration Toolkit
When using the using the ECU Measurement and Calibration Toolkit to access information from an ECU in LabVIEW, how do you access the timestamp of the XCP packet for various protocols (CAN,TCP or UDP)?
Using the poly MC DAQ Read vi NChan NSamp Time-Value XY Array, you can read out the timestamps and samples, as shown in the following screenshot below.
You can also set the Timing Source of the timestamps using the MC Set Property.vi under DAQ/XCP so that it either uses Operating System (OS) time, network hardware time, or ECU time.image.png
