This is not recommended because VeriStand uses hardware-timed single point (HWTSP) sampling mode. For cRIOs with DAQmx, such as cRIO 904x and cRIO 905x, pulse measurement is not supported, as per stated in
NI Hardware Support for VeriStand. NI-9361 is a counter input module and does not support pulse generation.
It is possible to do pulse measurement with NI-9361 using FPGA mode. However,
FPGA Addon Custom Device allows you to do pulse measurement and generation using
Speciality IO with C Series Digital I/O modules at a lower cost. Please refer to
Getting Started With NI FPGA Devices in NI VeriStand.
